99.5 7.3 won't start on side of road. - Ford Powerstroke Diesel Forum
post #1 of 20 Old 05-12-2013, 09:05 PM Thread Starter
mfd620's Avatar
Was driving down the road and it hesitated then died. Cranks no start. Scan gauge 2 says no ICP pressure.
Sent from AutoGuide.com App
mfd620 is offline
post #2 of 20 Old 05-12-2013, 09:17 PM Thread Starter
mfd620's Avatar
Has new t500 hpop about 600 miles ago. New IPR. Cranks and tack moves. No hpo. I unplugged ICP then IPR and no change in anything.
mfd620 is offline
post #3 of 20 Old 05-12-2013, 10:06 PM Thread Starter
mfd620's Avatar
Pulled it home and took about a mile and a half to build enough oil pressure to start. Stayed in the throttle to keep it running. Won't idle. Shut off when I got home and it won't start again. Any suggestions?
mfd620 is offline
post #4 of 20 Old 05-13-2013, 05:17 AM Thread Starter
mfd620's Avatar
Anyone??????
mfd620 is offline
post #5 of 20 Old 05-13-2013, 08:11 PM Thread Starter
mfd620's Avatar
Well it started right up this afternoon after work. Wth could it be?
mfd620 is offline
post #6 of 20 Old 05-14-2013, 05:33 AM Thread Starter
mfd620's Avatar
Wow no one can help?
mfd620 is offline
post #7 of 20 Old 05-14-2013, 09:11 AM
buckels's Avatar
Send a message via AIM to buckels Send a message via MSN to buckels Send a message via Yahoo to buckels
Have you replaced your CPS?
Drew
99 SD 6SPD manual
AFE Intake
Diamond Eye 4" turbo back exhaust
Wicked Wheel Gen2
PHP Hydra tunes by Bill
If you live in WA or OR check out these links.
buckels is offline
post #8 of 20 Old 05-14-2013, 08:37 PM Thread Starter
mfd620's Avatar
I have not replaced cps. Didn't think that would cause no high pressure oil.
mfd620 is offline
post #9 of 20 Old 05-15-2013, 10:45 AM
gndvisions's Avatar
check the oil resovoir,oil must be about an inch from the top,if full, low or no fuel pressure will cause a low icp code on a 7.3 l. if low fuel pressure you will need to do a inlet restriction test with a vaccum gauge(6 1n vac is max limit per ford)if there is a restriction the fuel tank must be dropped and the small screens will need to be cleaned(total of 2).
gndvisions is offline
post #10 of 20 Old 05-15-2013, 07:16 PM Thread Starter
mfd620's Avatar
Fuel pressure is good and I also just replaced the fuel pump with everything else. Did buzz test and two sound weak. Also same two had bad contributions when tested. Would an injector allow the hpop bleed off so bad that it wouldn't build hpo?
mfd620 is offline
