New ficm no start help - Ford Powerstroke Diesel Forum
post #1 of 15 Old 05-11-2013, 09:40 PM Thread Starter
Put a new ficm in today and it reads no volts when I put my voltage meter on the right terminal(of 4). Key turn on position and cranking, nothing. I removed and reinstalled about 6 times to make sure no pins bent and to make sure contact was good. The ficm is pre programmed. Any ideas? (2006 6.0l)
Coryfsc is offline
post #2 of 15 Old 05-11-2013, 10:02 PM
Fantom's Avatar
Quoted: 11 Post(s)
Feedback Score: 4 reviews
Did you check the FICM relay under the hood to make sure it's installed properly?
Inside the Battery Junction Box under the hood on the drivers side next to the the ABS control module. One of the square relays in the corner in the box. The relay number is 304
John
2004 Harley Davidson F250 #1191 - 6.0 Powerstroke
Studded - Lots Of Bulletproof Diesel Parts
Swamps 58v FICM - KC Stage 2 Turbo
Ported Intake - S&B CAI
100,000 Miles
Live in Northern California? Stop in here and say hi
Fantom is offline
post #3 of 15 Old 05-11-2013, 10:32 PM Thread Starter
I did do some research on it. Not sure how to test it. Just swing by the store in the morning a get one. Anyway to test just the relay? Or just get a new relay to see if it does the trick? Could I have blown it while changing out the ficm?
Coryfsc is offline
post #4 of 15 Old 05-12-2013, 08:22 AM Thread Starter
Ok. The relays work. They click. I pulled all the factory wrap off the wire and did a really good visual and condutivity test and re-rapped after installing again with same problem. I'm thinking its probably a bad rebuilt ficm.
Anything else I should look for? I also checked battery connectors and grounds to everything I could find.
Coryfsc is offline
post #5 of 15 Old 05-12-2013, 09:42 AM
Fantom's Avatar
Quoted: 11 Post(s)
Where'd you get the FICM? Try giving them a call and see if they know what might be wrong.
John
100,000 Miles
Fantom is offline
post #6 of 15 Old 05-12-2013, 02:09 PM Thread Starter
I got it from a local store. It's a remanufactured unit from G B remanufacturing. I did find the phone number for them and will try in the morning when they are open. Thank you for your help so far. I'll let everyone know heats up tomorrow.
Coryfsc is offline
post #7 of 15 Old 05-13-2013, 01:41 PM Thread Starter
Ok. Still nothing. Went a traded other for new and same problem. Checked for chaffing(non) replaced relay and fuse(nothing). What pin locations should have constant power to them? I have two with constant and two others have 1.6v and one has 3.4v. I don't know what to try from here. Any advise would be great. Thank you again for your help so far.
Coryfsc is offline
post #8 of 15 Old 05-13-2013, 01:42 PM Thread Starter
Sorry still the FICM problem.
Coryfsc is offline
post #9 of 15 Old 05-13-2013, 03:25 PM
Fantom's Avatar
Quoted: 11 Post(s)
Man, I sure wish I was a FICM expert. I'm sure someone, hopefully one of the ford techs will chime in here shortly.
John
100,000 Miles
Fantom is offline
post #10 of 15 Old 06-15-2013, 12:20 AM
does your ficm make a fast clicking noise "communicating with the injectors" if it's not making the clicking aka buzzing the ficm is bad.but you said you don't have power correct
if thats the case the wire is broken some where.
fatbastardf350 is offline
