Idlers,belts and such
How much trouble have you guys had with idlers? Mine seem to be good and snug, but I looked at them anyway this evening while I had everything else tore apart. Fan clutch bearing is making noise, so I guess I need to replace it.
This isn't really a 911 situation, so if this thread gets moved I understand. '02 E350 SD 7.3 PSD 152,000 miles Oil and fuel filter changes is about all I've had to do Did replace the cam sensor Other than the fact that a van is CIB to work on, this is by far the best vehicle I've ever owned. Also my first diesel. And yes, I make and burn my own fuel. |
are you sure its the fan clutch bearing?? ive seen TONS of water pumps go bad on 90-160k 7.3's.....its a very common failure.. |
I removed the air filter housing and let the tension off the belt and the water pump is TIGHT. I have motion in the fan only. Did I use the word "and" enough times? All the idlers, alternator, A/C Comp, PS pump and such seem to be good. I pried gentlty with a bar and the only place that moves is the fan. Worst part is the fact I don't really have time to mess with it right now.
Go figure. Bill |
if the engine is running at normal temp....and the belt doesnt seem in any dire need of replacement...you are probably OK to drive it for a while... |
