04 6.0 Will Crank but wont start - Ford Powerstroke Diesel Forum
post #1 of 5 Old 05-06-2013, 12:59 PM Thread Starter
Truck was running fine all day, ran fine and then I parked it. I went out twenty minutes later to crank it and its cranks but wont fire up. my injectors are cycling and everything. dash is lighting up, batterys are good to go. I ran diagnostics with my edge and got codes P0403, P0405, P0487. All egr bull****, I have egr delete also. I dont know why the trucks not running now, ran good all day. I cant afford a huge repair right now it has an 04 engine btw
03 6.0 CCSB FX4
6" fabtech suspension lift 37" Toyo M/T's
03blackpowerstroke is offline
post #2 of 5 Old 05-06-2013, 01:43 PM Thread Starter
Im going to let it cool down all night and see how it cranks when its cold
03 6.0 CCSB FX4
post #3 of 5 Old 05-06-2013, 06:23 PM
I had a cold start issue and from reading the sticky on this forum I confirmed that it was the FICM on mine that went bad. Check the sticky's on here they touched on a bunch of different reasons for cold and hot no start issues. Hope that helps.
dbn04psd is offline
post #4 of 5 Old 05-07-2013, 12:37 PM Thread Starter
still didnt fire up after sitting all night, I dont know where to begin troubleshooting this
03 6.0 CCSB FX4
post #5 of 5 Old 05-08-2013, 09:25 PM
Check your high oil pressure, and make sure it is up, and another thing to check is the a/c compressor. I have had two 6.0 not start because of a locked up a/c clutch.
1996 F350 CCLB, 4x4, 4:10, auto, tymar intake, 3" dp, 4" SS exhaust, gutless kitty, gauges, ts 6 pos, ebpv delete, ww2.
Trucknt is offline
