Need help ASAP....Wont stay running - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-20-2008, 03:56 PM Thread Starter
levi81's Avatar
hay im looking for all the help i can get if any of you guys can help pllllease let me know . i got a 94 7.3 powerstroke i replaced the cps,and the ecm and i still cant seem to keep it runnin . H E L P !!!
levi81 is offline
post #2 of 8 Old 02-20-2008, 03:59 PM
DKR
<--Pro Cooler Racer
DKR's Avatar
Sorry, I can't help ya, but I moved this post to it's own thread in our "911" section to hopefully speed up some help for you.
Good luck!
Eric
2007 F250 6.0l King Ranch CC LB
Sponsored by Innovative Diesel Performance
SCT XCal2 w/ Custom Files & FICM tuning
DashDAQ Series II; ARP Headstuds; AFE Stage 2 XP Intake w/ Proguard 7
Industrial Injection 190cc injectors; FASS 150/180; ITP Regulated Return
'03 Turbo Swap; Zex N2O Dry Shot; CFM Smallmouth Intake Elbow
Zoodad w/ Predator Screen; MBRP 4" Cool Duals Straight Piped
EGR Delete w/ full manifold; Coolant Bypass Filter; Train Horns
Eclipse AVN62D; High Idle Mod; BFG ATs 285-65/20s
Truck- 12.51sec @ 108mph @ ~7700lbs (1/4 mi)
Cooler- 39.93sec @ 12.12mph @ ~180lbs (1/8 mi)
Email:
DKR is offline
post #3 of 8 Old 02-20-2008, 04:59 PM
Any Codes???
mschn99 is offline
post #4 of 8 Old 02-20-2008, 05:22 PM
Strőkër~X's Avatar
can you give more symptoms?
smoke, chugging?
throw us a bone!
im still alive and kickin...find me on FB..."StrokerX1"
SOLD my truck, another Diesel within 2011
NOTE: if your on OK and need some PSD work done, i know a dealer tech who does the work....PM me!
Strőkër~X is offline
post #5 of 8 Old 02-20-2008, 08:00 PM Thread Starter
levi81's Avatar
yeah im using gas kerosene mix to spray in the intake but most of the time it will blow flames out and vaper lock my engine . its fried one starter and im seeing smoke out of the tailpipe it wont run for the most part but for a few secks .
levi81 is offline
post #6 of 8 Old 02-20-2008, 08:02 PM
DONT DO THAT.....
using starter fluids isnt the way to go...either it will start or it wont.....no need to possibly make anything worse...
to ask agian...have you ran it for codes??
we need to systematically take this one step at a time and diganose it rather than trying to do a backyard fix and possibly hurting more stuff...
mschn99 is offline
post #7 of 8 Old 02-20-2008, 08:07 PM Thread Starter
levi81's Avatar
Havent got a chance to run a diagnostic as of yet should be able to tomorow .
levi81 is offline
post #8 of 8 Old 02-20-2008, 08:08 PM
that is the #1 priority...do that before anything else...
mschn99 is offline
