Need Help Please - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-28-2013, 07:42 AM Thread Starter
Need Help Please
My 1997 7.3 was running great drove to a restaurant when I came out and started it things went crazy. The truck started but was shaking violently and had no power. I shut it off and restarted with the same results. It acts like it is misfiring. I made it home and pulled codes. P0603 and P0470. Someone told me the ebpv may be stuck closed when I extend the rod out of the sensor it pulls back in. Is this closed or open. I changed the cps just b/c I had a new one and hoping that may be the culprit but no help. any help would be greatly appreciated. Also the check engine light is on
stroking250 is offline
post #2 of 5 Old 04-28-2013, 08:07 AM
Dave at BCDiesel.ca's Avatar
Quoted: 4 Post(s)
BC Diesel
Sounds like it could be the IDM (Injector Drive Module)
Dave at BCDiesel.ca is offline
post #3 of 5 Old 04-28-2013, 08:21 AM Thread Starter
where is that located and how would i diagnose this
post #4 of 5 Old 04-28-2013, 03:53 PM
Quoted: 4 Post(s)
BC Diesel IDM Reply
They can be hard to diagnose short of throwing another one in, my shop diagnostic is to install one of the known good used ones I keep around and if problem goes away, install a new one unit. They are prone to moisture, more so in the E'Series but seen lots in the F'Series.
Swamps Diesel makes a high frequency IDM unit for a great price.
Hope this helps
Dave
post #5 of 5 Old 04-28-2013, 04:08 PM
Quoted: 133 Post(s)
Feedback Score: 3 reviews
I don't know what kind of scanner you have, they're Not all capable of properly scanning our trucks, I would expect to see a P1316 because you could be running on only 1/2 the engine is what it sounds like from your description.
Have a look at this, Both the IDM and the UVCH could be the culprit if that's true...
NoRalPh is offline
