cant get turbo out - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-26-2013, 10:23 AM Thread Starter
Big-john-obs's Avatar
Angry cant get turbo out
hey guys I have a 95 obs I need to replace my fuel pump but i can get the turbo out of the way the two bolts in the back are killing me any body got any tips p.s i am new to the site thank you.
Big-john-obs is offline
post #2 of 2 Old 04-26-2013, 12:24 PM
JSchuricht's Avatar
You don't need to remove the turbo to replace the fuel pump. You can get a 1 1/4" box wrench onto the banjo bolt.
If you still want to remove the turbo, there are 2 10mm bolts in the pedestal and 2 15mm nuts that are difficult to get to. You will need a 15mm swivel socket to have any hope of getting the nuts off. There isn't room for a socket and a separate swivel. Remove the EBPV to make the passenger side easier. The 10mm bolts in the pedestal are easier to get with a thin socket and a swivel. Once the turbo is out, grind the outside of the flange on the passenger side slightly so you can get to the 10mm bolt easier for reinstallation.
JSchuricht is offline
