turns over fast, but no start? - Ford Powerstroke Diesel Forum
post #1 of 12 Old 04-25-2013, 05:48 AM Thread Starter
2004 turns over rapidly, but no ignition at all. Drive it this morning and it ran fine, shut it off and now no start? Any ideas where to look? No symptoms at all prior to this.
Thx
Deadeye is offline
post #2 of 12 Old 04-25-2013, 05:57 AM Thread Starter
Also shows a P0264 code
Deadeye is offline
post #3 of 12 Old 04-25-2013, 12:20 PM
A high pressure oil leak can cause a no start. When the oil is cold, it builds more pressure, after the oil warms up,it can be harder to get to the 500 psi mark to get the sticks to fire. Can you monitor ICP while cranking?
1996 F350 CCLB, 4x4, 4:10, auto, tymar intake, 3" dp, 4" SS exhaust, gutless kitty, gauges, ts 6 pos, ebpv delete, ww2.
Trucknt is offline
post #4 of 12 Old 04-26-2013, 03:27 AM Thread Starter
Had it towed to the stealer yesterday. Waiting to hear from them what's up.
Deadeye is offline
post #5 of 12 Old 04-26-2013, 06:31 AM Thread Starter
Update. It was an oil pressure problem. The ICP sensor screen was clogged resulting in low oil pressure during cranking.
Deadeye is offline
post #6 of 12 Old 04-26-2013, 02:58 PM Thread Starter
New sensor, new screen $700.00
Deadeye is offline
post #7 of 12 Old 04-27-2013, 06:59 AM
I'm assuming its the IPR that's bad and not the ICP. Was the IPR bad, or the screen plugged? You can put a new screen on it.
Trucknt is offline
post #8 of 12 Old 04-28-2013, 07:06 AM Thread Starter
Good catch, yes, they replace the IPR and the screen. The tech said that a clogged screen will damage the regulator and so they replaced it. I now have a new screen and associated O rings in my tool box.
Will my scan gauge II read the HPOP pressure? and if so, what are the set up codes for the scan gauge?
Deadeye is offline
post #9 of 12 Old 04-28-2013, 07:09 AM
Dave at BCDiesel.ca's Avatar
Quoted: 4 Post(s)
New oil cooler screen, they did not replace/update the cooler? The price sounds decent for a dealer?
Confused?
Dave at BCDiesel.ca is offline
post #10 of 12 Old 04-28-2013, 07:22 AM
Dave- it was the IPR screen and valve, not the oil cooler screen.
Deadeye- Ford Specific XGauges : Linear Logic : Home of the ScanGauge
Looks like it supports it, scroll down to the 6.0 section, and you'll want the codes for the ICP (injection control pressure).
Trucknt is offline
