- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
Truck has low power, intermittent engine miss, stalls
I had a bad fuel pump, replaced it with Car Quest version.
Now I have an intermittent problem where the truck will die, or slow down and chug, and then run normally. I get an intermittent check engine light, but no codes on the scanner when light goes out. When the problem happens, it feels as though it's not getting any fuel. New pump, recently cleaned out gas tank and sending unit, new fuel filter, all done this weekend. My truck does have some Banks aftermarket goodies. The pump I replaced was a Bosch. Do you think the new pump is inadequate? Could I have some re-programmed flash in my computer that requires a more robust pump? Any ideas? Thanks. |
| Sponsored Links |
I have no idea what kind of truck you have.
It would be awesome to hook
I'm leaning toward the fuel pump being inadequate. I only changed it as a precautionary measure. Last week I had a clogged fuel filter that stalled the truck. I changed the fuel filter, and the truck ran fine. Or at least it started up and drove again. No biggie. But I noticed it felt a bit sluggish. It just didn't have the "oomph" my truck had before. The truck has a Banks full 4" exhast, K+N, aftermarket wastegate, etc...and who knows what other goodies. In healthy trim, it makes a lot of power, lots more than stock and is actually scary fast. My VW GTI would have a hard time outrunning my truck when it's happy. This leads me to believe the $167 special CarQuest pump simply isn't adequate. I noticed that even at idle I can hear it straining. When the truck isn't too hot, it'll run fine. But after about twenty minutes of beating on it, it just seems to start flagging. I've also noticed that at low RPMs my torque really feels solid, but at the upper RPM ranges it seems to be tailing off--and that sounds like fuel starvation to me. When the truck is cool, it'll start and idle like a champ, and then power progressively falls off. With the aftermarket goodies, you have to figure I'm making a good bit more power than stock. Sounds like I need a better pump. When you change only one thing and the problem crops up...kinda leads me in that direction. I've got no check engine light, no oil in my coolant, no coolant in my oil, no smoke from the tailpipe, a clean filter, a freshly cleaned tank, and 15 gallons of fresh from the pump fuel from a very busy gas station. The noisy fuel pump is definitely making me think it's time for an emergency trip to the parts store...:censord: |
You can hear the fuel pump?
Yeah, the fuel pump is LOUD and getting louder. With the windows up and the AC on, you can hear the pump over the motor at idle. I've never been able to hear it before. With the old pump, you couldn't even hear the pump if you put your head next to it on the frame rail; with this pump, I can hear it standing ten feet away from the truck. I think I might be answering my own question...if you believe what you read online and in the magazines, with the go fast goodies my truck has it's probably making an extra 50-75hp at least (18lbs of boost, big exhast, filter, etc) it probably needs a lot more fuel than stock and I've probably lunched this cheesy pump already. Any recommendations for one that IS up to the task of supporting 350hp and 600+ft/lbs? I'd be much oblidged....
That doesn't look like the pump I have on my truck. Did I mention the pump in question is the in-line pump on the frame rail just forward of the tank? It's a cylinder shaped pump with input and outpot on either end.
Is that the high pressure pump that sits under the filter assembly in your link? |
| Sponsored Links |
