Gray smoke and less power? - Ford Powerstroke Diesel Forum
post #1 of 8 Old 02-15-2008, 02:57 PM Thread Starter
siloped's Avatar
Possibly big problem. Truck used to bellow out black smoke, now its gray. Any thoughts? No water in oil or vice versa. No excessive blow-by eather
99 Xcab Sbed,4x4, 399.7 hp.
so close
DIY intake,
Optix Gauges
4" DIY exhaust 6" Stacks,
Dynomite STG 2 SingleShot 100hp injectors,
9 pos dp Tuner,
Drill & Slotted rotors,
boost fooler,
ccv mod,
foil delete,
map modifier,
B&M deep pan,
Firestone ride right,
hutched,
sonex shift kit,
BulletProof Trans
X-Wheel
6.0 IC
6.0 Trans Cooler
siloped is offline
post #2 of 8 Old 02-15-2008, 04:27 PM
pull the intake horn off and check the turbo. Grab onto the compressor wheel shaft and pull in and push out....see if you have any movement........sounds to me like its blue smoke from a failing turbo..
mschn99 is offline
post #3 of 8 Old 02-16-2008, 09:06 AM
Jack up truck 24" in rear and pressure test cooling system, egr cooler might be leaking. If it is, coolant will collect at front of intake.
Cablifter is offline
post #4 of 8 Old 02-16-2008, 05:08 PM Thread Starter
siloped's Avatar
Thanks for the input. I have noticed small amounts of blue smoke. But also white smoke sometimes at cold start up. But i didn't notice an egr system. If it was there i would have tried to bypass it. Spent gas just don't seem right in the intake
so close
DIY intake,
Optix Gauges
9 pos dp Tuner,
boost fooler,
ccv mod,
foil delete,
map modifier,
B&M deep pan,
hutched,
sonex shift kit,
BulletProof Trans
X-Wheel
6.0 IC
6.0 Trans Cooler
siloped is offline
post #5 of 8 Old 02-17-2008, 03:59 PM
RowdyOutfitters's Avatar
I had that problem a couple times. You may try changing the Cam Position Sensor. It fixed mine both times. I guess the timing would be off a touch and I would go from bellowing out black smoke to bellowing out gray smoke, especially if I had a load. Hope this helps..
RowdyOutfitters is offline
post #6 of 8 Old 02-17-2008, 05:38 PM Thread Starter
siloped's Avatar
Thanks for the thought on the cam sensor. I'll try it tomorrow since i got a spair and both are still under warrenty
so close
DIY intake,
Optix Gauges
9 pos dp Tuner,
boost fooler,
ccv mod,
foil delete,
map modifier,
B&M deep pan,
hutched,
sonex shift kit,
BulletProof Trans
X-Wheel
6.0 IC
6.0 Trans Cooler
siloped is offline
post #7 of 8 Old 02-17-2008, 05:55 PM
Cynic
Dirk's Avatar
I agree. This should be your first step.
Uhh.. What?
Best Car & Motorcycle Insurance | Auto/Moto Protection Today | FREE Trade-In Quote
Voluntary Banishment: Knowing when to leave.
Total Diesel Performance\Unlimited Diesel Performance\Diesel Innovations\BTS\Terminator Engineering\Swamp's Diesel Performance\Black Widow Diesel\Calvert Racing
Dirk is offline
post #8 of 8 Old 02-17-2008, 09:37 PM
Let's go B's!!!!
Southpaw's Avatar
Feedback Score: 5 reviews
I thought the EGR's were only on the 6.0's
Chris
2002 Crew Cab Long Bed
4" BDS, 35x13.50 Cooper STT on 20x10 Black Rockstars, and other stuff.....310,000 miles and counting...
2 Thessalonians 3 v.6-15
Southpaw is offline
