7.3 powerstroke won't start. HELP!!!! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-21-2013, 08:50 AM Thread Starter
Angry 7.3 powerstroke won't start. HELP!!!!
hey i have a 1995 f250 scab with a 7.3 power stroke 4x4. i was driving and blew a high pressure oil line and ran the motor out of oil. the low oil shut down kicked in. this has happened before when i bought the truck it had bad injector orings that i didn't know about and she ran dry. i filled her back up and she started and ran like a champ. now not so much I've filled the oil pan and the hpop. checked the fuel bowl heater and all fuses and relays and it doesn't even make an attempt to start just cranks. i tried ether and it won't even pop off ether. anyone got any ideas?
GRIZZLYDIESEL is offline
post #2 of 3 Old 04-21-2013, 09:30 AM
Whatever caused the low oil shutdown to kick in may be causing it not to start? Maybe an oil pressure sensor going bad?
Mission7.3 is offline
post #3 of 3 Old 04-21-2013, 09:33 AM
I have heard from a few guys depending on where you live you can actually get away with unplugging the fuel bowl heater so you don't run into the problem some people have with them coming apart and shorting out.
I would do research on it first and hope you figure out your issues bud!
