6.0 Engine noise - Ford Powerstroke Diesel Forum
post #1 of 39 Old 04-20-2013, 08:08 PM Thread Starter
6.0 Engine noise
I have an 04 with 135k and yesterday i started noticing a loud noise that sounds like a fan possibly a vacuum noise on acceleration. it sounds normal at an idle but the noise starts as soon as the truck does hot/cold when on the gas. i have searched around and tried some things that have been mentioned (checked intercooler boots and intake hoses) but nothing so far has seemed to fix it. ive never pulled anything very heavy with the truck and it doesnt get any hotter than it ever has 180-200f. if i unplug the vgt wire and rev the truck the noise isnt there. truck is alittle sluggish but nothing else seems amiss. has anyone else had this similar problem? what can be done about it?
racinstrat is offline
post #2 of 39 Old 04-20-2013, 08:15 PM
Like a boss!
Laferty's Avatar
You have a monitor?
2006 CCLB
BPD Oil Cooler, ARP Studs, ARP Rod Bolts, Smith Bro's Pushrods, 155/Stock Sticks, FICM Repair & Atlas 40, 4" MBRP Stainless, IPR Coolant Filter, AEM Cold Air,
EGR Delete, Blue spring, CCV mod, 6.4 Banjo's, CTS w/EGT,
2.5" lvl, 285/75 Toyo AT II's, Bilstein 5160's
Laferty is offline
post #3 of 39 Old 04-20-2013, 08:18 PM Thread Starter
i have a bully dog gt
post #4 of 39 Old 04-20-2013, 08:51 PM Thread Starter
just did a little driving it seems to sound more like its coming from the passenger side, and the tranny seems to take longer to shift than normal
post #5 of 39 Old 04-20-2013, 09:10 PM
Like a boss!
Laferty's Avatar
I had a similar sound but mine was headgaskets leaking. Does the bullydog show eot and ect?
2006 CCLB
Laferty is offline
post #6 of 39 Old 04-20-2013, 09:25 PM Thread Starter
im not sure what eot or ect are..it doesnt show any codes if that helps
post #7 of 39 Old 04-20-2013, 09:31 PM
Like a boss!
Laferty's Avatar
Engine oil temp and engine coolant temp. They are supposed to be around 5 difference and no more than 15. You destroyed my thought of what it might be when you mentioned the transmission shift and the sound is coming from the passenger side.
2006 CCLB
Laferty is offline
post #8 of 39 Old 04-20-2013, 09:42 PM Thread Starter
well it sounds like the passenger side when your sitting in the drivers seat..it doesnt sound like the whole motor making noise just off the the right side..if that makes sense..ive never really watched my oil temp only tranny and coolant..coolant usually runs 180-200 trannys never really ran a high number what should my eot run? i will drive it around tomorrow to get it to to temp to see what it runs..the trans shifts fine but it seems like it rides out to long before it shifts but it doesnt shift hard..always shifts like its a cold tranny..ive read so much about head gaskets and having stock bolts and a bully dog im hoping its not that..i also tried (hard) to pull the egr valve to clean/see if its wet..but i cant get that f****r out, any tips to remove it?
post #9 of 39 Old 04-20-2013, 09:51 PM
Like a boss!
Laferty's Avatar
Eot should be within 5 of whatever your ect is. Sounds simple and not to offend, but have you checked transmission fluid? What does it smell like? Check coolant and oil and look for signs of cross contamination.
2006 CCLB
Laferty is offline
post #10 of 39 Old 04-20-2013, 09:53 PM
MyTractorsSexy's Avatar
Quoted: 7 Post(s)
You have an air leak crack in boot or up pipe or exhaust leak. How much boost are you buding? It normally breaks at the flex pipe
07 F250-SOLD
2011 Black CC SB Lariat F250, 2015 Retrofit, MPD IC Piping, H&S Mini Maxx, 5"Flo-pro Exhaust, Sininster Egr Delete, Recon Smoked Lights, No Limit S2 Intake, 20% Tint, BDS 8" 4-Link Lift w/ Fox Shocks & Dual Steering Stabilizer, Toyo MT's, 2-Piece Fuel Maverick 22x12 Wheels, PTM Grille Surround, T REX X-Metal Grille, super bright leds 6500K heads and fogs, kenwood double din, 4 hertz 210W door speakers 2 JL TW3 10s kenwood amps.
Thanks to bigblack for selling me his truck
MyTractorsSexy is offline
