03 6.0 will not start - Ford Powerstroke Diesel Forum
post #1 of 6 Old 04-17-2013, 08:16 PM Thread Starter
Angry 03 6.0 will not start
The truck will run for 5 mins or so dose not start up real well, Idles terrible. Runs bout 45 to 60 psi
Fuel pres at secondry filter, no codes or lights... Then starts to idle terrible like it is starving for fuel
Then dies... Will take a few hours of sitting to get it started back up... Ipr? Icp? I have traced every wire and fuse... Thanks for any help....
J_lance_b is offline
post #2 of 6 Old 04-17-2013, 08:39 PM
Like a boss!
Laferty's Avatar
Not putting out any codes?
2006 CCLB
BPD Oil Cooler, ARP Studs, ARP Rod Bolts, Smith Bro's Pushrods, 155/Stock Sticks, FICM Repair & Atlas 40, 4" MBRP Stainless, IPR Coolant Filter, AEM Cold Air,
EGR Delete, Blue spring, CCV mod, 6.4 Banjo's, CTS w/EGT,
2.5" lvl, 285/75 Toyo AT II's, Bilstein 5160's
Laferty is offline
post #3 of 6 Old 04-18-2013, 10:25 AM Thread Starter
Not a one!
post #4 of 6 Old 04-18-2013, 10:49 AM
Brent Beeler's Avatar
Any type or monitor? Need some #s,
Sent from AutoGuide.com App
Brent Beeler is offline
post #5 of 6 Old 04-18-2013, 06:42 PM
rogerallen33's Avatar
might be high pressure oil leak,, if it starts cold and dies when it warms up, that would be the first thing I check, since their is no codes, but I have seen high pressure oil leaks throw injector codes as well,,, I have an earley 04 6.0 so it has the 03 6.0 which has the 03 motor, our trucks have the better high pressure oil system no stc fitting or dummy plugs to worrie about, so a high pressure oil leak is not that common but possiable, maybe your hpop is going bad, or the ficm,,,, check these things, I don't think it would be you irp, or icp sensor without having a code, this is were I would start but all these things are very expensive to replace so you don't wanna go throwing parts at it, you know it could be as simple as bad fuel, I only get my fuel from one place and the same pump everytime I top off, let me know what you find, if you can't figure it out i'll give you the number of my mechanic he completely rebuilt my motor ,,,,, big blue 04 f350 long bed 6in lift 35x12.5x20 nitto grapplers riding on massi rims,,, new pistons, rings, rod, and crank bearings, lifters, valves, head gaskets with arp head studs, egr delete, k&n cold air intake, blue spring upgrade, 03 rebuilt turbo 4 in turbo back straight pipe exhaust, running canned sct performance tune, soon to upgrade to custom tunes as soon as I upgrade my injectors, that's the only thing I didn't do when rebuilding my motor, ohh what kind of scanner did you scan your truck with.. not all scanners pick up on everything hope this helps you some let me know how it goes
rogerallen33 is offline
post #6 of 6 Old 04-18-2013, 06:45 PM
one more thing,,, have you replaced your fuel filters, if not go ahead and do it
