Early 99...NO POWER!!!
Here's the deal, i have n early 99 with a diy intake, fps, straight pipe and updated ecu with wildman 4 position chip. Truck was running great. Went into the store came out started the truck and it ran like $hit! Like it was backfiring through the intak and puffing smoke. I have removed the chip and newer computer and put the old one back in to start over. The truck now idels smoth like it use to. My problem is i can't build any power! The orginal ecu has a superchip set on tow safe. I have pulled codes and it only shows the intake heater code which i alread know about. ANY IDEAS???
THANKS |
check the fuel pressure......then check the harnesses under the valve covers
sounds good...at least i have a starting point. Were sould my fuel pressure be idleing and wot? Then when i check the harness what am i looking for or will it be that obvious?
thanks |
got her licked...spoke with friend that is a ford tech and he had me unplug the map and sure thing my map took a dump on me! i will install a new one tomorrow.
