03 7.3 coolant in oil HELP!!! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 04-09-2013, 04:35 PM Thread Starter
Question 03 7.3 coolant in oil HELP!!!
I have search and nothing quite matched. While on highway with cruise control on at 70 MPH everything seemed fine when I noticed the CHECK GAUGES lamp on and the temp pegged. As soon as I kicked off the cruise and started for the side of the road the temp when right to normal. With engine running I noticed the reservoir empty while slow loosening the cap water surged into the tank after a few slow tries I got it open with and it was nearly empty. I pulled the oil fill and there was steam. I put in water and watched a bit, no exhaust issues and water held. (nothing leaking anywhere either) I continued due to my location. The truck drove fine nothing wrong, in 30 min checked again and it need about a half a gallon of water and still had steam with oil fill off and no oil in water. Got home and searched everything. and thought with 135K on truck and cruising at 70 the water pump cavitated which affected flow which caused the over temp till RPM change and the a cavitation hole was created in the front cover. SO I took off the water pump to find nothing wrong with the front timing cover (damn). I fear I have a head gasket failure that is NOT related to the cylinder area. UNLESS the wealth of knowledge on this site can tell me something else like a weird fault in oil cooler which I thought would put oil in water (don't have that). I have to assume head gasket or crack somewhere that will require me to flatbed it to a garage. ANY HELP WILL BE MUCH APPRECIATED!!!! Thank you.
2003 F-350
7.3L Stock Turbo
AFE Stage II Dry
FS-2500
High pressure oil, head cross connect hose
Boost gage
Auto Trans
SRW
Crew cab
4X4
135K
GETPHILTAFISH TOW TRUCK is offline
post #2 of 5 Old 04-10-2013, 12:00 AM
444 ci's Avatar
I would say you have a bad oil cooler when they go bad you either have oil in your antifreeze or antifreeze in your oil. if your truck is making oil your oil cooler is your problem .they either rust out on the inside or the o rings go bad on the ends.
444 ci is offline
post #3 of 5 Old 04-10-2013, 05:17 AM Thread Starter
Thanks 444 ci,
If I take it apart what smoking gun am I look for to see if I found the problem? Thanks
2003 F-350
7.3L Stock Turbo
AFE Stage II Dry
FS-2500
Boost gage
Auto Trans
SRW
Crew cab
4X4
135K
post #4 of 5 Old 04-10-2013, 08:38 PM Thread Starter
Oil cooler and O rings looks good. I'm going to have it pressure tested while it's out. Put it all back together this weekend and see if by some miracle I found the problem and didn't even know it...HA HA. Then when the truth sets in I will drive it to the local diesel shop and stroke a major check.
2003 F-350
7.3L Stock Turbo
AFE Stage II Dry
FS-2500
Boost gage
Auto Trans
SRW
Crew cab
4X4
135K
post #5 of 5 Old 10-01-2013, 06:14 AM
Did you end up taking it to a shop or what happened?
stroked2001 is offline
