99 f350 cold start problem - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-07-2013, 03:18 PM Thread Starter
I have a 99 f350 psd and it will not start when cold. Need to run glowplugs at least 3 times before it will start. Pulled all 8 glow plugs and tested them they were all ok, but replaced them anyway. Replaced valve cover gaskets and harnesses and tried again. Truck will not start like before. Replacing glowplug solenoid next just looking for some other ideas before I run out of day because I don't have much time to work on this truck. Thanks.
Adam
ajolivette is offline
post #2 of 2 Old 04-07-2013, 07:13 PM
I have a 02 and same thing,was glowplug soleinoid make sure you check it with a ohm reader,cause still could be working just not supplying enough juice.
smoke on this is offline
