OBS lipe and white smoke - similar to UVCH - Ford Powerstroke Diesel Forum
post #1 of 1 Old 04-03-2013, 08:49 PM Thread Starter
POWERSMOKIN's Avatar
symptoms
huge lope, sounds like UVCH has gone bad
white smoke
no codes
this started a few days ago when i went to park at the airport. truck will lope like crazy like a uvch problem, but with no CEL. lots of white smoke. i can get it to idle and even move forward if i turn the chip all the way up. it will do this, and if i let it sit, it will start back up, and run fine, just like a uvch problem. but there arent any codes, like injector circuit high-low resistance.
anyone able sto shed some light? thanks.
~Mike Lewis
1996 F-350 CC LB PSD
Beans Stage 1's - 6637 Intake - SD HPOP - 5" Exhaust
E4OD w/ Shift Kit - Sky MFG Reverse Shackle
265,000MI
POWERSMOKIN is offline
