help need awsers!!!! idm replacment!!!??? ford f350 1995 - Ford Powerstroke Diesel Forum
post #1 of 5 Old 03-31-2013, 04:51 PM Thread Starter
97strokerman's Avatar
I jjust bought a '95 f350 that needs a new idm. I ordered one from o'riley but the one that came was one digit off. I wonder if it will work? The store closes at 8 and I am leaving in the morning so need answers and I cant find info on internet or ford website. Help!
97strokerman is offline
post #2 of 5 Old 03-31-2013, 04:59 PM
JD3020's Avatar
If its an IDM, then it will work. All 7.3 IDM's will interchange with one another.
Jimmy
97 F-250 ECLB 7.3/E4OD/4wd, 216k miles: FFD 250/200%'s, stock turbo, built trans, e-fuel, Swamps IDM, shimmed 910's, Melling LPOP, welded cam gear/modified pick-up tube. Built and tuned by me
97 F-250 ECSB project truck:250/2's, Gen 3, S468, SD axles, studs/springs, ZF-6
JD3020 is offline
post #3 of 5 Old 03-31-2013, 05:03 PM Thread Starter
the part i have is F5TF-12B599-AB the part at the store is F7TF-12B599-AB the part is $400 i want to be sure before i buy it
post #4 of 5 Old 03-31-2013, 05:22 PM Thread Starter
post #5 of 5 Old 03-31-2013, 05:34 PM
JD3020's Avatar
It shows it as an IDM, so it will work. You can run any year IDM from any 7.3 and it will work. They are all essentially the same thing.
Jimmy
JD3020 is offline
