06 f350 problems - Ford Powerstroke Diesel Forum
post #1 of 1 Old 03-30-2013, 04:17 AM Thread Starter
06 f350 problems
2006 f350 problems
I got a 06 f350, it stars ok dies few times till warm, smokes a little at idle, codes are P0283
P0282
P0284
P2617, it's gutless idles rough, I pulled the ficm and connector to Injector 8 and one pin is slightly black, and 2ficm plugd dont clip in they pretty much fell out when i unbolted ficm,should I change injector 8 pig tale and ficm harness anyone have similar problems??
Also I have the 4x4 and low range light as well as brake light on, and it constantly beeps until I play with tcase harness sometimes it goes away, it's gott be shorting but I'm curious if there's any common problems
jmccart is offline
