6.4L No Turbo and sounds weird after changing oil cooler - Ford Powerstroke Diesel Forum
post #1 of 2 Old 03-29-2013, 02:59 AM Thread Starter
Got the truck back together after changing the oil cooler and I don't have any turbo pressure on the gage, turbo sounds like it has a slight rubbing or something, and seems to be ideling high. Any ideas?
Homebuldr1 is offline
post #2 of 2 Old 03-29-2013, 03:08 AM
05_PSD_Erik's Avatar
I have never removed the 6.4 turbos before. But with any turbo, I would make sure you have all the connections tight as a loose up pipe can cause major lack of boost. The rubbing sound could be a turbo problem, or it could be the loose up pipe vibrating against the turbo feed inlet. Just the metal of the pipe and the flange rubbing together from the vibration of the truck. Good luck finding your issue!
2009 Subaru WRX Premium
Type RS BOV
CAI
Muffler Delete
Had to park it with some real diesel muscle....
05_PSD_Erik is offline
Tags
6.4l , turbo issue problem
