Injector Removal - Ford Powerstroke Diesel Forum
Old 01-26-2008, 07:18 PM
Injector Removal
Hey all! This is my first pull of injectors on a 99 7.3l. I pulled the oil galley drain plugs and the bolt(s) to the injector and its seated in there pretty good. My book is talking about some special tool for removal. Anyone using basic items from around the shop to remove? Let me know and any techniques advice would be greatly appreciated.
Old 01-26-2008, 07:39 PM
1999-2003 Ford 7.3L Powerstroke Injectors
there is a link that has step by step instructions that tell you how to do it your self. i hope that helps you
Old 01-26-2008, 08:13 PM
put a pry bar under the injector clamp and carefully pry off the head of the engine... the injector will pop right out of its cup and become free.
Old 01-26-2008, 10:17 PM
I am pullin the injector cups (sleeves) as well. Do you recommend any use of threadlocker on the cups?
Old 01-26-2008, 10:21 PM
i sure hope you have the instillation and removal tool for them...
yes...you threadlock two spots on them....the highest and lowest spot on them on the round side....(top and bottom basically)
Old 01-26-2008, 11:04 PM
i bought the installer and im gonna try the CAT bolt that some guys were talk about for the removal tool. it only cost 8 bucks so if it doesnt work its not the end of the world right.
Old 02-03-2008, 09:17 PM
you can use a simple pry bar if that doesnt work. i used a flat nail puller.
