loss of power on my 7.3 powerstroke - Ford Powerstroke Diesel Forum
post #1 of 7 Old 01-26-2008, 04:33 PM Thread Starter
I'd like to explain my problem - When I started my truck up this morning it was very hard to start and it had been sitting overnight. When it warmed up it started to "hunts" and when you push the gas peddle it will idle. But then I put it into gear to drive, the truck won't move and it's lacking all it's power. Just wondering if anyone has any ideas as to what is wrong with my truck.
While driving it last night I started to lose power. At first I could only go as fast as 40 km/h and then down to 30 and just before reaching my destination I could only go 20 km/h.
Any ideas please forward your information to me.
Any help is appreciated.
glen b is offline
post #2 of 7 Old 02-05-2008, 05:29 PM
dzlpwrd's Avatar
is it cold enough for your fuel to gel? it sounds like it is running out of fuel mabey ice in your fuel filter
dzlpwrd is offline
post #3 of 7 Old 02-05-2008, 05:46 PM
ADMIN AND TECH
SCUFFY828's Avatar
does sound like a possible fuel problem possibly, need to run a fuel prerssure test , shrader vale on the side of the fuel filter , will climb to around 45 -50 lbs when cranking and should increase up to 100lbs while driving under load , also make sure oil is full and in good condition , maintenance is a major part of keeping the engine running properly , get codes pulled and see if there are any , need ton start here , there are some other things it could be ,start with the basics
ITS STOCK
SCUFFY828 is offline
post #4 of 7 Old 02-06-2008, 09:09 AM
Yeah I would start with checking fuel filters and the fuel pressure. Make sure the pump kicks on and its stays on for about 20 seconds when you turn the key on. You may also want to see if you have any injector codes or wiring harness(injector) codes.
Ford Power Stroke Tech
If your in Mobile,AL look me up if you have any issues.
Long Live the Diesel!!!
nunly81 is offline
post #5 of 7 Old 02-11-2008, 11:32 AM
My Truck was having the same problem and the dealer found a bad harness that runs under the valve cover that goes to the injectors. I guess the torque from the motor puts stress on this harness.
GSandman is offline
post #6 of 7 Old 02-12-2008, 03:04 PM
tractor nut's Avatar
what year is it but it sounds like you could have lost one whole bank of injrctors the valve cover gasket also houses the wires for the injectors and if it finally gets thin and shorts a whire you lose that whole bank of injectors truck will not move ang little to no response on the pedal.
2002 ford f 350 with banks 4 inch exhaust, afe stage 2 air intake and a edge evolution set on the tow setting.ats ported housing and a wicked wheel with a turbo master adjustable wastegate and a south bend dual friction kevlar and ceramic heay duty towing clutch.
tractor nut is offline
post #7 of 7 Old 02-12-2008, 03:20 PM
my .02 When mine did exactly that it was 0-rings. Had them replaced everything runs good.
97 F-350, 7.3 psd, xlt, limited edition, obs, dually, E40d at, 410 r axle, reg. cab, 8ft bed, 145000 miles, DIY Tymar intake (napa filter) CCV mod. fpr bb mod, HPX crossover pipe, SS Bully steps, Reese Fifth wheel hitch, CB Radio, 3" DP /4" back w/cat delete and 4" flow-thru muffler w/5" tip.
Triflex is offline
