Helpp - Ford Powerstroke Diesel Forum
post #1 of 22 Old 01-25-2008, 11:29 AM Thread Starter
COLLEGE KID
lifewitlooie's Avatar
Send a message via AIM to lifewitlooie
Helpp
I drove my truck to work this morning, cold start. I cycled the glow plugs a few times and it eventually started. that was at 0615. 1210 i get in my truck to start it and its cranks but doesnt turn over. I keep doing it and that crank gets weaker and weaker so i stopped. I know batterys are charged. I tried to jump anyway on drivers side battery didnt work. I just locked it up and came home.... any ideas???? The only thing funny i got going on is the starter cable broke and i slide underneath the truck whenever it falls of and hook it back on there good enough to starter up.. help please
If u dont wanna type call me. 7738926621 looie
Class of Aug 17, CFD
lifewitlooie is offline
post #2 of 22 Old 01-25-2008, 11:36 AM Thread Starter
COLLEGE KID
Exclamation
post #3 of 22 Old 01-25-2008, 11:44 AM
Desert Shield/Storm Vet
vitalidle's Avatar
Hmm well start with the basics first I guess and make sure your batteries are fully charged. You have plenty of fuel? Your oil is full?
2002 F-250 4x4 EC, SRW, SB
Auto 93,000 miles
DP Tuner F5
ATS Compressor and 1.0 Exhaust housing high flow back plate
Turbo Back 4" Silverline Exhaust Mbrp Muffler Delete
Isspro Trans,Pyro,Boost Triple Pod
Fumoto Oil Drain Valve
AIH Delete With Boost Fitting
vitalidle is offline
post #4 of 22 Old 01-25-2008, 11:44 AM
TXbroker's Avatar
My old 95 did that when the harness chaffed on the side of the motor. Its been so long I cant remember which side but it was closer to the back fo the block.
Paul
2005 F250 4X4 CC 6.0 FX4 Lariat
All stock
Lots of Toys, cylinder count is now 31:
TXbroker is offline
post #5 of 22 Old 01-25-2008, 11:48 AM
vitalidle's Avatar
Also check your fuses. Could be the fuel heater element fuse blown.
Auto 93,000 miles
DP Tuner F5
post #6 of 22 Old 01-25-2008, 11:49 AM Thread Starter
COLLEGE KID
Harness chaffed? Ill check it out
Check Check Check
I need as many ideas as possible and the easiest fixes lol I cant bring my computer to my truck. I can bring some tools and know how though.
post #7 of 22 Old 01-25-2008, 11:53 AM
vitalidle's Avatar
Okay make sure you don't have a drain on the starter or ignitions system. Do you have a meter? When cranking the starter check to make sure you battery voltage doesn't drop below 10.5 volts. Also drain you fuel filter housing and make sure when you crank the motor your housing is filling with fuel. Could be fuel pump.
Auto 93,000 miles
DP Tuner F5
post #8 of 22 Old 01-25-2008, 11:58 AM Thread Starter
COLLEGE KID
ok, kool. Hey Whats the IPR valve. I was reading a similar post and marc said to change IPR O Rings, Is that the fuel filter?
post #9 of 22 Old 01-25-2008, 12:11 PM
vitalidle's Avatar
No thats the injection pressure regulator on your hpop.
Auto 93,000 miles
DP Tuner F5
post #10 of 22 Old 01-25-2008, 12:14 PM Thread Starter
COLLEGE KID
OK, I am off to the races.... I was supposed to go take my CDL test today.. Its either that or fix my truck.. i am undecided. Ill do both. Here is what im going to do.
Im gonna drain the Fuel bowl and then turn her on and see if it fills up... I dont wanna change fuel filter cuz i changed it myself less than 1500 miles ago. And im going to check the valve cover harness... and jiggle it or something, reconnnect it. Thanks for the help keep it coming!
