Crank Sensor Plastic Housing Broken - Ford Powerstroke Diesel Forum
post #1 of 3 Old 03-24-2013, 12:33 PM Thread Starter
So I got the 8mm bolt out and was GENTLY rotating the ckp sensor back and forth in a twisting motion appx 1/8" each way to unseat the o ring and SNAP...the crank sensor magnet came out with the plastic housing left inside the hole...do i have to take off the ac compressor to get this out or should a pick and some finess do the trick? I'll try to get a pic up here shortly...
Name:	Ckp broke.jpg
05 Excursion Eddie Bauer 4x4 6.0 178k Dfuser Coolant Filter, Blue Spring, Zoodad Mod, BPD 48v FICM, Bilstein Shocks, Updated HFCM plug, DC Power 190A. Upgraded charging cables,BPD Water Pump, BPD Radiator, Riff Raff CAC Boots, BPD Egr Cooler, AFE Rear Diff Cover, BPD Billet Caps
There's no reason to go in there...ever! I sense it as a holy man.
Kyle K is offline
post #2 of 3 Old 03-28-2013, 07:47 PM Thread Starter
your best bet is to pull the ac compressor so you can get a good look at it
Kyle K is offline
post #3 of 3 Old 03-28-2013, 07:48 PM Thread Starter
hey thanks man. worked like a charm. got a hook pick on it and it popped right out
Kyle K is offline
