new turbo...no oil pressure - Ford Powerstroke Diesel Forum
post #1 of 16 Old 03-23-2013, 06:29 PM Thread Starter
Hi everyone, I have tried researching this all day and I have come up empty. I just blew my factory turbo last week and I installed a new Powermax turbo and SCT tuner yesterday. Ran fine all day yesterday but this morning when i backed out of the driveway my oil pressure gauge dropped and the truck quit. now it will not start and i am getting no oil pressure reading on the gauge. there are DTCs right now. I dont know where to start other than take it in to a shop to get it scanned. Please help.
metallicafan4885 is offline
post #2 of 16 Old 03-23-2013, 06:58 PM Thread Starter
Sorry....there are NO DTCs right now.
post #3 of 16 Old 03-23-2013, 06:59 PM
hello what dtc's are present?
nj powerstroke is offline
post #4 of 16 Old 03-23-2013, 07:00 PM
what engine?
post #5 of 16 Old 03-23-2013, 07:02 PM
what happen to the old turbo what made it fail?
post #6 of 16 Old 03-23-2013, 07:57 PM Thread Starter
2005 F350 FX4....6.0L, egr delete, oil cooler replaced, STC fitting replaced, 4" turbo back Magnaflow SS exhaust
I was on my way back from a car show going 75 down the highway and the bearings in the turbo started grinding and going out then it locked up and lost all boost.
post #7 of 16 Old 03-24-2013, 10:52 AM
huj
Feedback Score: 3 reviews
remove oil filter have someone crank the engine see if oil level goes up in the housing if yes possibly bad sensor if not lpop or pressure regulator stuck bottom of front cover behind harmonic ballancer take a allen wrench to get it out when out the spring comes out sleve sometimes gets stuck check for jesus parts
huj is offline
post #8 of 16 Old 03-24-2013, 11:06 AM
WWW.COMPIGNTECH.COM
Quoted: 16 Post(s)
Feedback Score: 10 reviews
A bad oil pressure switch will NOT cause a no start. If your turbo ground up the bearings like you said than I would imagine your LPOP sucked them up and chewed up the gearotor in the pump causing a no LPO situation.
l BRYAN l
COMPIGNTECH .COM
Look us up on Facebook
COMPRESSION IGNITION TECHNOLOGIES
l 2005 l Ford F250 l FTX l
[A Few Odds-N-Ends]
Tuscany is offline
post #9 of 16 Old 03-24-2013, 01:54 PM
ya it could be that the lp pump went starving the turbo causing that to fail i would tare down might have some debrie in the oil system. if u have no low pressure i would pull the pump and check it out
post #10 of 16 Old 03-24-2013, 02:12 PM Thread Starter
not that this means anything but when the turbo bearings were screaming and finally went, i suppose some valve in the turbo busted cause it was pumping oil into my exhaust and into my intercooler and out the exhaust just billowing out smoke as the truck ran.
