Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 09-06-2006, 12:27 PM
doogie 1000 doogie 1000 is offline
HELP! 7.3L powerstroke, no power
Good afternoon. I have been a long time reader of this forum, and have always found an answer to my 7.3l powerstroke issues, and for that I thank you. This is the first direct question I have to ask. Situation: Parked truck over weekend. Went to start truck on Monday, and it drove fine for 20 minutes, when I noticed a large volume of white smoke pooring out of the exhaust. I pulled over to investigate, and found that a rat had taken up residence in my air cleaner box, and there was a plastic bag completely blocking the airflow. Removed the bag and rat, and continued on, and everthing seemed to be okay. The next morning, I went to start it, and it seemed down on power. Drove it 10 more miles, parked it. Later that afternoon, I started it, but it has NO power under the pedal at all. It seems to idle rough, but it won't go 5mph downhill. In nuetral, I can get the RPMs up, but thats it. I drained the fuel, checked the air cleaner and flow. All seems to check out. The wires don't look chewed or any other evidence of rodent damage. Can anyone help???? Oh yeah, code reader produced no codes.
Old 09-06-2006, 12:31 PM
Jon
Tournaments Won: 1
Posts: n/a
Where was he?
Under the filter or on top?
Old 09-06-2006, 12:34 PM
The debris was all pre-filter. I am pretty sure nothing got into the intake.
Old 09-06-2006, 05:01 PM
mschn99 mschn99 is offline
without a code i am guessing here...but my best guess would be under valve cover harnnesses came disconnected or partially disconnected. My reccomencation since it wont cost anything is to get those valve coversoff and inspect the harnesses....DO NOT disturb the valve cover gasket itself...get the valve covers off and carefully inspect the connector on the inside to see if it isnt fully connected to the gasket..
Old 09-06-2006, 06:31 PM
F-350MAN F-350MAN is offline
If your looking at the front of the truck under the hood look down next to the battery on the right hand side if the hose from the cooler to the turbo has come off your turbo won't produce any boost make sure the hose is on tight the truck will run fine but no turbo.. i've heard this is common with the 7.3 and check to make sure the rat hasn't chewed through it also
Old 09-06-2006, 06:52 PM
mech2161 mech2161 is offline
Look for wires chewed by the rat, they seem to love them for some reason.
Old 09-07-2006, 07:29 AM
Warheads02 Warheads02 is offline
Performed checks Recommended
Just to set things straight This is my truck were working on. Just didn't have the access to speak to you guys yet. Thanks to your comments and sugggestions. Checked the connectors at the valve covers, pulled every sensor connector and looked for corrosion / replaced connection, ----Added some oil too just to fill it completly (so it was a little low). When we started this help process the truck would start but run rough and no power. Currently the truck bellows white smoke from the exhaust as we are cranking, but won't start at all now. Am going to have it towed to the house today, and rent a reader that hopefully will give me the killer code today. I'm going to replace the GPR also, because I did have small problems last winter here in NM. until I plugged it in each night, then never a prob. Gonna take all of next week off and work on this until I get it fixed (hopefully). I have downloaded the code book for PSD and generic. Again, Thanks for the help Will work until stumped and then ask...
Old 09-07-2006, 07:38 AM
actually take the valve covers off and inspect the connections under the valve covers.....
Old 09-07-2006, 08:49 AM
Will do, thanks again
