Oil cooler change and now big problems 6.0 - Ford Powerstroke Diesel Forum
post #1 of 6 Old 03-23-2013, 01:51 PM Thread Starter
So I changed my oil cooler and put on an egr delete kit. The truck started fine after cranking the engine for a little bit and ran good for about 3 minutes it was cold so it kicked into high idle. I was about ready to drive it when it died. It was puking oil out of the back of the engine. The turbo return is out of place would this puke a gallon of oil in just a few seconds? Would that in turn starve to HPOP? Please help fast if I need parts I need to get them today. Thanks
2006 F-250 Crew Cab. Black. Blue spring kit, EGR Delete, SCT tuner
tinmanb1b is offline
post #2 of 6 Old 03-23-2013, 02:14 PM
rdaffin's Avatar
Re: Oil cooler change and now big problems 6.0
I did the same thing. Pull the turbo and make sure everything stays in place when you reinstall. Top off the oil and check for leaks. Should not be a big deal.
Sent from AutoGuide.com App
2004 CCSB 4x4, blue spring, SCT , 4" exhaust, Gearhead tunes, egr delete, ELC-1, Coolant filter, ARP Studs, CCV Mod, 6" lift, 35" Toyo A/T II.
rdaffin is offline
post #3 of 6 Old 03-23-2013, 05:24 PM Thread Starter
Thanks man, I guess that the turbo oil return had popped out when I put the turbo in. I didn't know that it would force a gallon and a half out brand new T6 oil on to the floor. That's about a 40 dollar oil spill. So how do you get a broke off dip stick out of the tube is there any trick to this? It was a long day....
post #4 of 6 Old 03-24-2013, 04:41 AM
rdaffin's Avatar
I know that feeling! Lol. Small pair of needle nose pliers on the dipstick. I have a super skinny set I bought from Snap-on, but you might find some at a hobby store.
rdaffin is offline
post #5 of 6 Old 03-26-2013, 06:59 PM Thread Starter
Here is a bad story with a good ending. I tried to get the dipstick out with needle nose and a pick and all I did was push it way farther into the tube. I figured I was up Poop creek so as a last ditch effort I put a couple drops of super glue on the head of a small nail and let it rest on the top of the dipstick for several hours and the dipstick pulled right out with the nail. Then to top it off the stealership only wants 10 bucks for a new dipstick. It is true, good things happen to dumb people..
post #6 of 6 Old 03-27-2013, 08:19 AM
Slacker
Evil Eye's Avatar
Quoted: 219 Post(s)
Feedback Score: 4 reviews
Congrats and glad you got it figured out.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
