EGR cooler question - Ford Powerstroke Diesel Forum
Old 01-20-2008, 02:03 PM
EGR cooler question
Does anyone have a picture of the EGR cooler? Im not sure what it looks like or where it is. I want to disconnect it to see if it fixes my smoke and low coolant problems. Also is this ok to do? Is it going to effect anything else?
Old 01-20-2008, 02:12 PM
I dont believe it can be blocked, As far as coolant is concerned. You can block off the hot air gases, but not coolant. I wanted to figure out an aftermarket way to run it.
bThe egr can be shut down but the oil cooler is there too. It also uses the coolant flow.
