08 6.4L creamy looking Oil overflowing from Degas bottle
I’ve been having Radiator issues, leaking for some time now, already had it replaced twice under warranty but because of money issues haven’t been able to replace it a third time out of warranty. I’ve been just trying to keep it full, ran low the other day, gages didn’t read hot, and no service or engine lights came on but I could tell by the sound it was hot. Stopped to add fluid and there was creamy oil overflowing out of the degas bottle, almost looked like an off white paint. My question is... is there any other oil, fluid, besides the engine oil that can get into the cooling system, by the way there is no water/coolant in the engine oil. I’m assuming it’s the oil cooler, as over the phone a diesel mechanic I trust says that’s probably the problem and the oil pressure is much greater than the cooling pressure so it’s only went one way, oil into coolant. Is there any other possibility besides the oil cooler as the problem, could it be any other type oil/fluid say like transmission? I would greatly appreciate any advice or input.
Also many many thanks to Ken for his hard work and time on making this manual available... http://www.powerstroke.org/forum/mem...-kenjamin.html |
Your oil cooler ruptured.
Thanks for the info!!
Your welcome. Sorry to hear about it bud. It is a major PITA to change.
I'm about to attempt the repair myself, and going to be installing a new radiator as well. The manual says to flush the cooling system before removing the oil cooler, any suggestions on this, seems to me if the cooler is leaking or ruptured, without the engine running, a flush will now put water in the engine oil, it doesn't have any in there at the moment!
I have a 08 radiator im looking to sell if your interested, it is pretty new looking
http://www.powerstroke.org/forum/per...-radiator.html |
It won't put water or coolant into the oil as the oil system operates at a much higher working pressure than the cooling system. That said flushing with a ruptured oil cooler will only continue to dump oil into he cooling system. In your case you have to swap the oil cooler then flush the cooling system.
Cool, thanks!!
Well tonight after a week working off and on, at times wanting to take a sledge hammer to it (the F'n turbo), I finally got to the oil cooler, couldnt see any visable damage or evidence of oil getting into the cooling side so I seriously started second guessing myself and even tho I checked it when it all happened and seemed normal.................. I pulled the dip on the tranny tonight and low and behold the same creamy looking stuff on the dip stick, so apparently its in the tranny!!!!! I just spent money i didnt have on oil cooler, turbo kit, and other gaskets and seals, and not to mention the MAJOR pain in the *** it is to do with the body on and now I'm confused, pissed, broke, and my truck is tore completely apart and when I put it back together tomorrow I feel Im backl at square one!! Any suggestions?????
If you have creamy stuff in your trans your in deep trouble. Your going to be buying a new tranny soon.
