I have a question for everybody - Ford Powerstroke Diesel Forum
Old 01-19-2008, 09:15 AM
i have a problem with my 7.3l 250 Year99 i just change the oil about a week ago.. and i have check it afterwards and everything was fine.. then i check it again and it was barley on the dipstick so i put more oil in it.. couple days later the same thing.. But i cant find and oil leaks and where the oil is going.. So my question would be does anyone have an idea of where the oil is going or what could be the problem??
Old 01-19-2008, 09:26 AM
I'm not sure but sounds like the injector o-rings to me. I could be wrong if I am than here is a bump for you.
Old 01-19-2008, 11:19 AM
I dnt think it would be the o-rings, cuz wouldnt that be coming from your HPOP resovoir?..........i thought it was a seperate deal from your engine oil..........................but if im wrong and the o-rings are bad on the injectors your oil would just be runnin past your injectors and into the crank case leaving no sign of a leak
Old 01-19-2008, 12:04 PM
the oi in the hpop is the same oil as in the engine,the inj orings wiil leak and the oil will be burnt thru the engine
