Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 09-04-2006, 11:52 AM
sharkstower sharkstower is offline
I put it all back together and I think Its wrong!!!!
HElp I dont know what I did wrong I just put the head back on the passagener side of my 97 7.3 and tryed to start and it wont turn over at all or so I think. Did I put one of those lifter poles in wrong? I may have just destroyed my engin I dont know please any info Id love. Im pretty scared that I did somthing majorly wrong here.
Old 09-04-2006, 12:02 PM
fordnut85 fordnut85 is offline
7.3 tech, supporter
I would try pulling the glow plugs and turning the motor over by hand, just a thought
Old 09-04-2006, 12:08 PM
mschn99 mschn99 is offline
lets start from scratch.....are you trying to start it with the starter or roll it over by hand?? did you try to roll it over by hand first??
Did it turn over at all?? give more info about what is actually going on...
Old 09-04-2006, 12:20 PM
ok I havnt done anything by hand. only starter. I read a old post about trying to turn it over with all the injector wires diconected to insure no oil in the pistions Tryed that nothing really happened so I hooked the wires back up and tried. Just kinda moved the truck alittle but didnt feel like it turned over.So I turn the key and just kinda hear a click.
Old 09-04-2006, 12:22 PM
try to roll it over by hand. It will be tight, you will need a decent bar, but lets find out if its a problem with the motor, or a starter/battery issue...
Old 09-04-2006, 12:23 PM
where do I hook the bar onto?
Old 09-04-2006, 12:28 PM
the bolt on the crankshaft pulley, i dont remember if its 18mm, 21mm(13/16) or 24mm(15/16) though....you will need a short extention as well....
when i said bar, i meant breaker bar or large wratchet....
Old 09-04-2006, 12:34 PM
something else i want you to try, is if it wont roll over clockwise when looking at it towards the front (just like your trying to tighten the crank bolt), try going back a little. see if it is bound in a spot, or just locked up totally....this is only if it wont roll over. Honestly, it sounds like a possible wiring issue to me (fingers are crossed) as usually there is a pretty big bang if the motor itself is locked up...not just a starter clank hitting the flexplate...
Old 09-04-2006, 12:36 PM
thanks Im working on it now trying to figure out how to get onto it
Old 09-04-2006, 12:37 PM
if i was you, i would go ahead and take the fan and shroud out for now just to simplify this process of figureing out what is goin on......
