code p0603 - Ford Powerstroke Diesel Forum
Old 01-15-2008, 03:50 AM
code p0603
internal control mod kam error is this just a sensor or what truck wont start when the engine is cold and this code keeps coming up what do i need to do 03 f350 7.3
Old 01-15-2008, 03:54 AM
Desert Shield/Storm Vet
Are you running a tuner or have you disconnected your batteries lately? If so that will throw that code. Have you checked your glow plug relay or gp's?
ADMIN AND TECH
have you been runing a programmer or plug in chip of any kind, if so have you tried to change programs , or anything , its possible to have wiped the pcm mmemory, need to know that first
Old 01-15-2008, 03:58 AM
i have a super chip programmer yes i have changed programs
Old 01-15-2008, 03:59 AM
no i have not checked gp relays or gps
Old 01-15-2008, 04:15 AM
ADMIN AND TECH
if you changed programs , that will give you that code , you may have another issue , also are you sure when you changed programs , was it allowed to finish correctly
Old 01-15-2008, 04:17 AM
yes. but i changed programs last week and this started yesterday morning
Old 01-15-2008, 04:19 AM
i also cleared the dtcs 3 times and this keeps coming up
Old 01-15-2008, 04:25 AM
ADMIN AND TECH
thats gonna be a tough one ,i guess its possible for the pcm to have taken a dump, its few and far between you see that, does the wait to stat light come on when the key is cycled
Old 01-15-2008, 04:27 AM
yes it does if i set it back to stock might that work
