Dead truck - Ford Powerstroke Diesel Forum
Old 01-09-2008, 05:08 PM
Unhappy Dead truck
Need help fast. I have a 1999 F250 7.3 Lt. Powerstroke. The truck will idle for 10 to 15 mins then die. No stuttering, just dies. I replaced the fuel filter, checked all fluid levels, and have no warning lights. After replacing the fuel filter I was able to drive about 6 miles before the truck just shut off. It started about a week before driving on the freeway at 65 I felt a slight stuttering. Now I can't keep it running. I have added water remover to the fuel tank and injector cleaner but still dies after about 15 mins under idle in the driveway. Please give me a direction to go.
Old 01-09-2008, 05:15 PM
Replace the CPS, it is under recall right now and Ford should replace it for you. Otherwise they are $25.
Old 01-09-2008, 05:18 PM
Infidel
Welcome to the .ORG and where are you located?
Craig
Old 01-09-2008, 05:19 PM
screen in fuel tank p/u as well if youve got crud in your tank it could be plugging up
