Oi pouring out front, driver's bottom side of 95 7.3 - Ford Powerstroke Diesel Forum
Old 03-01-2013, 11:43 AM
Just fired up my truck in the driveway. fortunately, I got out to get something out of the garage. came back to see oil pouring onto the ground. Looks like it's coming from the driver's front. Going to fire it up and try to spot leak. Seems like there are oil lines on the bottom, front, driver's side. ???
Old 03-01-2013, 12:00 PM
Just fired it up again. leaking from a gasket on the ??? Is it the oil pump ? Is there a service manual that is really good ? Ford Factory manual ? I gotta get to work. Going to try to make it...
Old 03-01-2013, 12:21 PM
Is it the Oil Cooler maybe?
Oil Cooler O-ring replacement R and R - PowerStrokeNation : Ford Powerstroke Diesel Forum
Old 03-01-2013, 01:52 PM
Thx ! It Is the oil cooler Gaskets & o-rings, new oil & anti-freeze while I'm at it Whew... ez fix with 300k on the ole girl, I just need another 300k
Old 03-01-2013, 07:35 PM
well they're not that fun to do.
getting the caps to seat with the new o rings in there can be tough. i like to use a huge rubber mallet. stand it on the ground. have someone hold it straight up. then pound the caps on.
or you might be able to use a press.
also, i recall there is one mounting bolt near the front that's a bit tricky
