Here is what i have so far!!!!
![]() question??? I need my Truck to run right!!!!!!Any help is appriciated!!!! |
If the UVCH's check out ok, remove the fittings for the gauge and re-install the schraeder valve. Have a buddy depress the schraeder while you turn over the engine to purge any air and see if that fixes the problem.
So today i'd hoped that the fuel pressure problem was something clogging the FPR so took it out and cleaned it all out..did have a couple pieces of what looked like plastic shavings in the screen...well no luck!!!
![]() Took a picture and a video on my phone so if it helps here it is.. The picture shows the fuel pressure at the FPR where the shraider valve was and the video shows the motor running pressure and revving pressure! Lack of fuel pressure - YouTube ![]() What would be my next step????Can't beleive that a brand new fuel pump from Guzzles site would go bad in less than a month...did notice that while i had the FPR off that when i cranked the motor that it was filling the fuel bowl.. Any help getting my PSD running the way it should so i can find out how my TS-6 chip works and my new gauges!!!Think I'll order AE tonight just so i have it !! want to check my injectors any way!!! |
