oil loss of quart per 100mi cannot find! - Ford Powerstroke Diesel Forum
Old 02-23-2013, 03:54 AM
I am lossing a battle with oil consumption and hope someone has a new direction for me to go. Every 100mi I lose a quart of oil. there is a little in the valley and maybe a drop or two when the vehicle sits overnight. Had it to a garage that is very good and their stumped as well. Doubt its burning that much because of no new smoke patterns? Help if able before I go crazy! Pete p
Old 02-23-2013, 06:23 AM
You forgot to post the Yr/Mdl/Engine of your truck
Old 02-23-2013, 12:57 PM
Ah yes I did neglect those...Its an 02 F-350 dually with a 7.3 Thanks!
Old 02-23-2013, 02:55 PM
These engines can burn a lot of oil and still not smoke. Not saying that's your issue, I'm just saying that I would believe its possible to burn a quart ever 100 miles and not have much noticeable smoke. How sudden of an issue is this? did it just happen one day?
Old 02-23-2013, 06:58 PM
WNY Biodiesel Co-op
injector o rings ,the hp oil is pushed past the o rings into the fuel and burned
Old 02-23-2013, 10:39 PM
check your coolent your oil might be going there. if your oil is going into your coolent you have a bad oil cooler or your orings in your oil cooler are shot.
Old 02-24-2013, 02:13 AM
Thanks guys for the quick response! I will check those areas and post what i have found.
Old 02-24-2013, 10:00 AM
absolutely agree with this possibility. only thing is usually it will smoke blue like a banshee if it is the case.
OP, remove the fuel filter. have a look in that fuel bowl.
