Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 08-21-2006, 03:39 PM
DART505 DART505 is offline
CPS Eater
Ok it is easier to link you to the trama than go thru it all over again but the short of it is cam sensor failing as fast as they can be replaced! No face contact involved.Oh in case you don't know me I'm a professional shop working on plenty of these for over 10 years & nothing like i'm going thru with my own!:throwup:
Link on problem: http://forums.thedieselstop.com/ubbt...=0#Post3002579
Thanks for the info!
Old 08-21-2006, 04:28 PM
mschn99 mschn99 is offline
Banished
is there any possibility you have a bent trigger wheel or a loose camshaft thrust bearing?? i see you said no face contact, but it is still possible to take the magnet within the sensor out withe a too small airgap. Im grasping at straws here, dont get me wrong but it is a very slight possibility....
Old 08-21-2006, 05:55 PM
I understand & appriciate ANY feed back!It has been mentioned that cam walk can be the issue but & a small butt. The motor has 12 to 13,000 miles on it sense New pretty much.
Old 08-21-2006, 05:58 PM
Banished
thats about all i can come up with off the top of my head man......the only other thing i could see as a very slight possiblility is the port for the sensor is not casted in the proper spot and the sensor isnt getting a true signal, but i would expect drivablility problems with that senerio...
any of these are unlikely possibilities though, although i guess that comes with strange problems...
Old 08-21-2006, 06:10 PM
Thanks Marc!I just don't see how it would walk that much! Bean said same thing.
Old 08-21-2006, 06:12 PM
Banished
i had one about seven months ago. It didnt eat them, but threw intermittant codes that four dealers tried to get rid of. It ended up being a walking cam, but that motor had 260k on it.......and it never had a stall once.....
Old 08-21-2006, 06:46 PM
lilredpowerstroke lilredpowerstroke is offline
Ballin' on a budget
My truck was spitting out CPS then the dealership found a wire that was grounding out in the maiin wiring harness. Fixed the wire and no more CPS being spit out. Just my .
Old 08-21-2006, 08:27 PM
super_stroke super_stroke is offline
Power Strokeaholic
i was thinkin maybe a bad wire or connection TJ. but i got no clue. im still on the one it came with. knockin on wood and crossin my fingers!!
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
