- HOME
- FORUMS
- GARAGE
- ARTICLES
- CHAT
- CLASSIFIEDS
- VIDEOS
- TECH
- STORE
No Start
Hello, long time lurker, first time poster.
Yesterday I replaced the gaskets and o-rings on both my HPOP and IPR, putting new o-rings on the oil line connectors coming out of the HPOP as well due to a very large oil leak. Now the truck won't start. HPOP reservoir is full we filled it before trying to start, fuel filter bowl is full, filled it as well. Tach is moving, oil pressure is reading in the middle of the normal range on the oil gauge. No smoke from the tailpipe at all. Voltage on the batteries are 11.5 when cranking. Fuse #22 and 17 are fine and the truck has a new fuel heater on it a couple of years ago (before I decided to start working on the truck myself). However we are hearing a wierd noise coming from the HPOP itself...it is possible that with 280k miles on the truck taking the HPOP off and moving it around did something to it and/or the IPR (loosen up some trash or debris) and damaged the pump? I'm picking up a 3000psi gauge today to check the oil pressure on the lines going to the oil rail to see what type of pressure I have. I put an injector in a couple of months ago and it was hard to start after doing that, but only had to turn it over on and off for about 15 min before she fired right up (didn't know about filling the reservoir at that time) and has run like a champ before this. HELP PLEASE!!!! any other ideas would be great. |
| Sponsored Links |
You took the HPOP all the way out?? My question would then be, are you sure you got the splines for the pump fulley engaged back into the gear. If not, you my not be spinning the pump and/or could have damaged the splines on the pump that conect it to the gear. I would take the inspection cover off that you took off the first time to pull the bolt for the HPOP gear on the front of the motor and crank it to verify the gear is turning |
I pulled the plate off of the front of the reservoir, took off the 18mm bolt, then took the two 10mm bolts off of the back where the entire HPOP is bolted to the reservoir and took it out towards the turbo. ***EDIT*** Ok, I see what you are talking about, when it quits raining I'll pull the cover and see, however it didn't look splined to me, just the bolt holding the pump onto the shaft. |
Ok, still have to check the gear but with the gauge on the line going to the driver side oil rail has 0 psi when the truck is turning over. Question.....will the IPR not working properly cause it to have no oil pressure on the line? The IPR is confusing me on how it works, does the magnet keep pressure against the valve to keep the pressure low or does it pull the valve open to let the pressure build? |
Ok, will do that tomorrow....thanks again for all the help. I'm about at my wits end but with 277k miles on the truck I can't complain too much, except when Ford screwed me over on a couple of things when the fuel heater went out. |
You are a genius Marc, you were exactly right on what it was. Lined the pump up on the gear and after filling up the fuel and HPOP reservoir she fired first time.
Thanks again for all the help
| Sponsored Links |
