no cold start...ready to snap
Okay, my 2000 F350 has me at my wits end.
rebuilt engine (deglaze, new rings, bearings and seals) new HPOP new CPS new IPC sensor glow plug system functioning (good plugs/relay, draws about 175A on activation) new fuel pressure regulator new fuel filter tested fuel pump at pump outlet, pegs a 100psi gauge fuel lines clear full tank of fresh fuel HPOP res full IPR solenoid replaced by previous owner. The truck fired fine at my buddy's shop (room temp) now that it is at home outside at 20F, it won't start, the tach bounces during cranking, batteries are good. Yesterday, after 20 min of cranking, the truck finally started. When running, there are no DTC's Last edited by alberta 7.3; 12-16-2007 at 02:52 PM. |
ya gotta plug these beasties in when the temp drops. Last winter..drained my batts a couple of times trying to get my Beastie to fire. No Techie by any defination, but make sure your glow plugs are working and if able, plug in that heater when the temp drops.
how far have you driven it?? You need to put about 50 miles on that motor after having it that far apart to get the oil systems fully primed (mainly the high pressure oil systems...)
