Starter relay on fender wall - Ford Powerstroke Diesel Forum
Old 12-13-2007, 03:26 PM
Does any one know where the 4 or so wires go? I know one set of fusible links goes to the GPR then there is the battery, a 16gau from the battery and two more sets of fusible links? Anything will help, Thanks
Old 12-14-2007, 02:50 AM
Gun Nut
No clue but I'll give this a bump top the top for ya to see if anyone else can help.
Old 12-14-2007, 03:03 AM
Send a message via AIM to cowboymafia
i had that same problem i can go outside and check for yah
Old 12-14-2007, 11:06 AM
The only way I think it can go is the 3 fusible links are with the battery and the other side of the relay the 18gau goes to the starter
Old 12-14-2007, 01:57 PM
BIG TRUCK, SMALL DRIVER
The starter wire goes by itself, all others on the battery side.
Old 12-14-2007, 06:06 PM
Thanks to all that looked. I didnt notice it untill it got cold outside. I changed my positive battery cable this summer and it didnt get cold enough till last week. So if any one is wondering your truck will start cold till about 40 degres with out even noticing you are using your glowplugs.
