stall, and lope after acceleration. help!
Well i got all my issues fixed with my IDM. However im still having some issues that i think are from oil pressure?
Last night on the way to the fuel station, i accelerated a bit harder to see how it was running. When i let off, the truck went into the lope mode where it just lopes hard, then stalls out. wiggled all my wiring, let it sit a couple minutes...finally it cranked up and started on the 9th try. i put it in drive and kept the RPMs high because that seems to save it for whatever reason.
since then its been totally fine. except on lunch just now it stalled in the mcdonalds drive thru. started right up fine and ran great then. Any ideas?"
Truck has been warm every time
Brand new CPS
tried unplugging the ICP, no change just throw's the CEL
Every wiring connector has been cleaned, it had over 3/4 tank of fuel with additive, oil is perfect, new fuel filter.
Thanks for any help!
