fried pcm on 02 7.3??? need help - Ford Powerstroke Diesel Forum
Old 02-02-2013, 11:37 AM
So today I went to start my truck and with it being 20 degrees out she hates life starting unless its plugged in... anyways I kept cranking till my batts don't wanna crank it no more...
Now I have a super chips micro max tuner with the high perf tune on
And I have a edge evo I bought off eBay that's vin locked (won't refund me, and I know shouldn't have bought it) that I use for gauges... anyway when my batts died it started retiring to stock and it said unlocking and pcm went through the stages... now I can change the tunes wit the edge but my super chips now tells me its not the original truck.... anyway to fix this or do I need to get a new pcm and programmers? and my truck wont start
Thanks could use help asap
Old 02-02-2013, 12:06 PM
Ok got it started but I can tell its not on the same tune as before and its blowing blue smoke and none of my gauges work
Old 02-02-2013, 12:23 PM
I'm getting codes
P1316
P0381
P1668
Old 02-02-2013, 12:39 PM
You have an IDM issue, either power to it (fuse-relay-connection) the IDM has failed, or a connection to the injectors themselves (UVCH connectors).
I would start with a Buzz Test and see what the IDM resolves from that, you would get some new codes after the test. I don't know if the Edge will do that for you, or you may need a professional diagnostic scanner (Ford, Snap-On, AutoEnginuity etc.)
Edit: none of your Gauges work? On an '02 have a look at this connector first -> POTENTIAL ELECTRICAL CORROSION if your truck is like mine......
Maybe this too -> https://b7445ba3-a-62cb3a1a-s-sites....attredirects=0
Old 02-02-2013, 12:44 PM
Hmm.. it almost seems as if its trying to double tune the pcm.. cyz like I said the super chips was on highperf when the edge tweaked and made itself return to stock and now I can't use my super chips anymore cuz it says my truck isn't the original.. or the Vin lock process swapped between the super chips and edge some how..
Right now with the edge on a tune it runs fine just none of my gauges work. Cept engine temp and oil pressure and fuel
And my glow plug light stays on and the check engine light stays on even if I clear the dtcs
Old 02-02-2013, 12:54 PM
OK, but you have 2 IDM codes for a reason.
Your PCM does sound confused, take all that crap off maybe
Old 02-02-2013, 12:59 PM
yeah the PCM is confused, i returned the edge to stock and still nothing removed it from the obdII plug and everything... but now on stock i give it gas it blows blue smoke and acts like the ebpv is shut all the time there is no turbo at all on stock... on edge tune #3 it runs fine. just with no gauges
im starting to think when the edge bugged out it flashed the other trucks stuff on so i cant use my superchips anymore..
if i cant fix this somehow im just gunna get a new pcm and buy a dam chip.. ive had enough of programmers lol
