towed home by a dang dodge gasser - Ford Powerstroke Diesel Forum
Old 12-01-2007, 07:57 AM
Had a cps issue and installed new one. Problem is it didnt fix the issues I was having. Dieing twice a day in the morning then fine. Well today it died three time and after the third there was no restart. Broke down in the middle of the road, but thankfully a guy stopped and asked if I need a pull. Thankfully less than a 1/2 mile from the crib. Checked fuel filter and fuses, talked too ABobb and have no ideas. No ses light either, cranks and cdanks but no start. Reads on the tach and oil pressure when cranking but no start. Need help, any ideas? Thinking about getting another cps and trying that. What are the odds of getting a bad one.
Old 12-01-2007, 08:00 AM
duct tape & zip ties
hey at least you didn't push it home. You need to get a diagnostic computer, run a buzz test. I wonder if your IDM is bad.
Old 12-01-2007, 08:07 AM
idm? what is that?
Old 12-01-2007, 08:15 AM
Originally Posted by bmiller2000 View Post
idm? what is that?
Injector Drive Modual.
Old 12-01-2007, 09:49 AM
and how do I check it. New cps and still nothing. Is there anyway to check the hpop?
Old 02-25-2008, 03:30 PM
Ok, this is going pretty far out there but check it. I had the same problem on a 00 250. I changed the cps twice and still no fix. it turns out that I had a bad cap on my seperator and the thing would lose prime or something crazy and die for no reason. I ended up putting a new filter in with a new cap and never had the problem since. Just a fluke that I ended up fixing the problem like that. Just thought Id pass it on.
Juston
Old 08-25-2009, 02:32 AM
Glow Plug Relay , Possably
