96 cranks wont start without ether - Ford Powerstroke Diesel Forum
Old 01-29-2013, 02:53 PM
just started actin up the past few days will crank but not start without a short ether spray once started will run great just will not start on its own cold warm don't matter has new fuel pump idm icp fuel filter gp relay fresh oil air filter im stumped someone help
Old 01-29-2013, 04:03 PM
Low Compression?
Is it turning fast enough on the starter? (they won't even try to start unless they're spinning at least 150rpm)
Old 01-29-2013, 04:04 PM
yes tach shows around 250 or so
Old 01-29-2013, 04:06 PM
also replaced ipr and while trying to start no smoke from tail pipe so I know its not getting any fuel im lost and money running really low lol
Old 01-29-2013, 04:25 PM
I wouldn't think it was low compression cause it just started doing it one day out of the blue I drove 300 miles made a left turn it died and ever sense it will only start with a short spray and ive replaced all parts in the last two days after this started
Old 01-29-2013, 04:27 PM
also no smoke out of tail pipes while cranking
Old 01-31-2013, 04:35 PM
ever figure this out?
Old 01-31-2013, 04:39 PM
Yes it's the hpop not enough pressure to start
Old 02-01-2013, 07:02 AM
how did you fix it? new HPOP?
Old 02-01-2013, 09:47 AM
Yes new hpop fixed it runs awesome now
