Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 08-03-2006, 03:17 AM
tigly2 tigly2 is offline
1994 PSD no start - need help ASAP
I have a 1994 F-SuperDuty with a 7.3 PSD (turbo) with 201K miles on it. I recently replace the low pressure cut-off switch on the A/C, Started the motor and let it idle for about 10-15 minutes to see if the A/C was working properly (it was) and I shut the engine off. About an hour later I started the engine normally to leave. It started fine and I backed out of my driveway. About as soon as I started forward, the engine just died - shut off completely! I tried restarting it several times but it would crank but not fire. I tried a small shot of a starting fluid and it would "pop off" for a short time. This led me to think that it was a fuel problem. I checked the fuel filter and found that it was starting to get plugged so I replaced it. Still would not start. I also knew that the fuel pump was slowly leaking from the weep hole and decided that this was a good time to replace it too. Still would not start. I talked to the Mech at the local Ford garage and he thought it was possibly the Cam Position Sensor. Replaced that too and still will not start. I cracked the banjo bolt on the fuel pump outlet while a friend cranked it over and it seemed to have good flow. tightened the banjo bolt and cracked the line at the back of the heads while it was being cranked over. Fuel ran out in a stream a little larged than a pencil lead but no gush or spray. (I do not know if that is normal). I pulled the allen plug on the high oil pressure resevoir and it was low and I filled it, tried to start it (no start) checked the resevoir again and it was still full. I replace both batteries with ones out of my other truck - both new and it crank over just as fast, if not faster than it ever has but the tach during cranking is only about 400rpm. Oil pressure never comes off of 0 psi. I even tried grounding the wire from the sending unit to "fool" the system but, even with the wire grounded the needle only went to the "R" on the normal and it still will not start. The volts read about 9 after the glow plugs initially trip off with the "wait to start" light which is about normal for my truck until it starts. I have had 4 (yes four) code readers on my truck with NO codes showing up. I am running out of Ideas and would GREATLY APPRECIATE any and all help that anyone could give me. Sorry for being such a lengthy post but, I was trying to give as much info as possible right away. Again, thanks in advance for any help.
Old 08-03-2006, 03:51 AM
Brian Brian is offline
welcome to the forum! its early so give your thread a couple of hours for some good advice.
brian
Old 08-03-2006, 07:36 AM
mschn99 mschn99 is offline
if your only reading nine volts after the glow plugs kick off, it will never start, you need over 11 while cranking for the IDM to run the injectors....
im more concerned with the lack of base engine oil pressure. without that your truck will never start. First of all, just to get this out of the way, you have checked your oil level to make sure you didnt have a massive leak and lose a bunch of oil??? and secondly, have you tried manually checking the base engine oil pressure???
Old 08-03-2006, 02:52 PM
No oil leaks - dipstick shows full. I put an oil pressure guage into the allen screw hole in the high pressure resevoir several weeks ago. I never really checked the oil pressure while cranking but, after cold start up it went to 60-65 lbs. At warm idle the guage showed about 20lbs. During cranking now the needle does NOT move. I do not know if it was like that before.
Old 08-03-2006, 03:08 PM
harald@bd harald@bd is offline
Marc ,when you come up with the answer for this one please let me know.
Had simular once on97 and it was fuel heater shorted out.
Old 08-03-2006, 04:57 PM
Just had a ASE Senior Master Tech over here to check the truck out with his scanner. He said that the IPR was working electronically. He disconnected the lines from the High pressure pump, installed a pressure guage and watched it as I cranked it over. NO pressure at all! He suggested that I put a new high pressure pump in and also change out the IPR right away because he said that when the pump goes out, they usually throw alot of crap through the IPR and even though it was working electronically it may not be working mechanically.
Old 08-03-2006, 09:19 PM
chancelor chancelor is offline
I dont remember exactly but when I had my 97 I had a simular problem I had to fill the timing chain cover housing with oil so the sensor would read that it had oil pressure before it would crank. I replaced everything known to man before I had an old man from a little mech shop on the south side to help me with the problem. Probably not any help but that was my experience
