stuck on side of the road Laffiette, La.
my husband is on the side of the highway!
was running performance tune driving down the highway, engine started vibrating. Stalled but will start again but still vibrating. Returned back to stock tune and is still doing the same thing. |
can he move the truck at all
how is his fuel situation? did he just fill up? how long sinec the filters have been changed?
yes he can move the truck, but he does not want to. he is affraid it will do more damage. it is not a fuel issue, all filters are fine. it kind of sounds like it is loosing compression.
is anything leakin. if you can ask him if he hit any kind of bump or large pot hole before this happend something that could have knocked a connection loose
no leaks , did not hit anything that would have knocked anything loose. the truck has been puking fluid out of the degas bottle only on a heavy throttle, also he said to look at his sig too.
truck smoking at all???
no there is no smoke comming off engine or out of tail pipe.
the engine is not missing, it is loping
the same thing the oxman is going through happend to me tonight but i have a diff engine and my chip goes in to my pcm. i hit a bump and it knocked my chip loose on my pcm and caused my truck to run real ruff with no power.
