Stranded no crank, 6.4 tbcm
I was cruising at 120kmph when cruise shut itself off and wouldn't re engage. I pulled over and my dash board lit up like a Christmas tree showing everything. I turned it off and tried to restart but wouldn't crank. My h&s mini maxx won't communicate with it. When it's plugged in the theft light is on and a bunch of other issues. I unplugged it and all it says is check charging system when I do a system check. When I pull my keys out the theft light flicks 3 times then is off. I google'd already and only found one guy's starter fuse was blown on his 2012 I swapped my 30amp for a different 30 amp but it didn't do anything. Please help
When my mini maxx is on the dash read trailer brake control module fault but it doesn't read that when my mini maxx is unplugged. Won't communicate with the comp in any situation I try
Anyone? Anything? Even if it makes no sense just something I could try? I'm 3 hours from home on the side of a highway
Tow truck is here ill be taking it to a dealership and will post the fix tomorrow assuming they can get it fixed tomorrow
Sorry man...I've never heard of that happening. Let us know what it was!
I'm guessing it's a harness issue
^ I'm sure it will be a 5 cent fuse or a slightly disconnected harness but I'll find out tomorrow. I tried checking ground's, worn wires, anything loose or disconnected but couldn't find anything. thanks for the suggestion
This turned out to be a minimaxx tuning issue. Not the minimaxx itself. I had a dirty airfilter, (it appeared fine but it wasn't) and the tuning in the minimaxx had set defueling levels very low on trans temp, engine oil temp, and egt. the constant defueling while running on the hot setting caused it to throw 30 codes. So i'm going to be running on no power till I can take it to my performance guy and find appropriate defueling levels.
