Truck in water. Need best course of action - Ford Powerstroke Diesel Forum
Old 01-17-2013, 05:09 AM
Ok guys, I was out hunting last night and a thunderstorm rolled in on us. On the way out I took a different trail with ruts deeper than I realized. Needless to say the truck is in water to the top of the front bumper and the bottom of the back bumper. I didn't have a means of getting it out so I had to leave it. I know starting it back up could cause huge damage I there's water in the tailpipe but I figured I could take the uppipes off to see if it made it by the turbo. If its dry I can't foresee any major issues. Except for the starter and fuel pump being completely submerged ex overnight. Please offer guidance. Truck is a 2002 f250 7.3 4x4
Thanks guys
Old 01-17-2013, 06:09 AM
Fresh water? I don't think that's high enough to cause you any problems....
Old 01-17-2013, 06:10 AM
Yea fresh water
Old 01-17-2013, 06:26 AM
So what could have gotten soaked that isn't exposed to that much water driving through a 1ft puddle at 30mph?
Ford uses pretty good connectors!
Pull it out, start it up, drive it around a bit to dry it off and maybe check the fluids (trans-TC-Diffs) for evidence that water might have gotten in. Other than that, I don't see where it could have done any real harm....
Maybe go for a long drive, after the fluid check, to dry out the hubs & brakes.
Old 01-17-2013, 06:41 AM
Personally I'd just change the diffs and transfer case fluids plus re-grease everything since it was sitting so long in water.
Sent from my iPhone using AutoGuide.com App
Old 01-17-2013, 06:46 AM
Pull it out, fire it up and grab a roll of quarters and head off to the car wash. I put my work truck through this type of abuse on a normal basis. If it was my personal truck Id take the time to change out all fluids but coolant and maybe brake fld...but my truck gets baby'd
Old 01-17-2013, 07:42 AM
Awesome. Thanks guys. Ill pull it out and change the fluids shouldn't be too bad. Thanks again!!
Old 01-17-2013, 07:50 AM
And PICS!! GRAB SOME PICS!!!
Old 01-17-2013, 08:30 AM
Old 01-17-2013, 08:59 AM
Re: Truck in water. Need best course of action
Pics or it didn't happen! Haha that's what we used to say with our buddies when they, "hooked up with someone"
