Engine idling when sunk in lake, now has hydraulic lock! - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-15-2007, 07:51 AM Thread Starter
I have a 99 E350 with 7.3 195K miles. A friend was launching a jetski with it, backed the rear wheels in water, put in park, put emrgency brake on, got out of the van to tie ski to pier and the van slid into the water while running. Poor thing sank up to the roof, it did float for a min. enough time to drift away from pier.
The engine now must have a hydraulic lock because it will not turn over.
I'm thinking I should remove the valve covers and exhaust and either remove glow plugs or somehow hold the exhaust valves open then hand crank engine over to remove water.
Any other ideas on that. Also what kind of engine damage should I expect? Bent push rods and bent connecting rods. How do I check?
02e3504x4 is offline
post #2 of 5 Old 11-15-2007, 08:05 AM
duct tape & zip ties
bigcountrysg's Avatar
The engine is most likely full of water. That is why it will not turn over. I suggest you drain the oil and all the other fluids, Then attempt to turn the engine over by hand.
I dealt with this alot when I was in the corps. Dang drivers would forget to switch the deep water fording valve and fill the engine up with water. I would drain the oil, remove the glowplugs and crank engine by hand. Then I would drain the fuel tank and refill with fresh diesel. Then I would refill with oil change the oil filter, install the glowplugs and attempt to crank the engine over with the starter. Most of the time the engine would fire up and run ok with no problems.
Was this salt water or fresh water?
Good luck I am sure techs will give you all the info you need to get your van back up and running.
Your Actions Today, Decide Your Future Tomorrow
2005 6.0 Crew Cab Long Box Lariat, current truck
2004 6.0 destroyed by contaminated fuel
2002 7.3L burnt
bigcountrysg is offline
post #3 of 5 Old 11-15-2007, 08:21 AM
Cynic
Dirk's Avatar
I completely agree.
Sell the van asap. Electrical problems are soon to follow.
Best Car & Motorcycle Insurance | Auto/Moto Protection Today | FREE Trade-In Quote
Voluntary Banishment: Knowing when to leave.
Total Diesel Performance\Unlimited Diesel Performance\Diesel Innovations\BTS\Terminator Engineering\Swamp's Diesel Performance\Black Widow Diesel\Calvert Racing
Dirk is offline
post #4 of 5 Old 11-15-2007, 09:16 AM Thread Starter
It was fresh water. The insurance totalled it. I replaced it with a 2002 E350 cargo 7.3 with a 4x4 quigley conversion. I bought the 99 15-passenger back from the insurance co. to get the interior, rear air & heat, cruise control, ect. off from it.
I have changed the fluids removed the cruise and installed it on the 02. I'm in the process of removing the glow plugs and thought i'd research things on the internet when I found your forum and joined. I like your forum and appreciate the help. I wanted to make sure there were not any quirks removing the glow plugs. As normal everything is hard to get to and see what your doing. I'll keep you posted on progress, thanks
post #5 of 5 Old 11-15-2007, 05:19 PM
7.3 tech, supporter
fordnut85's Avatar
Don't try and turn if over with the starter. Like stated before, remove the glow plugs drain all the fluids and turn it over by hand. The refill the fluids and WITH THE GLOW PLUGS STILL REMOVED crank it over with the starter a few times. The best way to do this is to jump the solenoid rather than hitting the key as to not inject fuel into the chamber. Then reinstall the glow plugs and cross your fingers and fire it up.
Duane
1994.5 F-350, PSD, 5spd, Crew cab, 2wd, DRW
10k mod
Idle control mod
homeade exhaust brake
Tymar intake
fordnut85 is offline
