throttle response please help asap
it has done it at least 4 times in the last month, i would be cruising normal speed all of a sudden it will turn CHECK ENGINE light and throttle wont respond y will stay iddle, the engine does not sound any different, i would pull over and the car will continue at iddle speed, after a minute or two it will respond and like nothing happend, please help.
FIRST - if you want help you HAVE to let us know something about your truck (they're Not all the same
)What Year? What Motor? What Truck? |
throttle response please hel asap
you right< thanks for pointing that out, my truck is a 99 f-250 7.3 powerstroke.
Here's where I'd start, there are two small wires under the steering column cover that go to the OverDrive button at the end of the Shift Selector. It it not uncommon for them to chafe through there and draw-down the sensor line to the TPS (Throttle Position Sensor) at the top of the Accelerator Pedal.
Look at this link -> https://b7445ba3-a-62cb3a1a-s-sites....attredirects=0 You may not be blowing the fuse yet, just confusing the PCM with the partial short. This may not be it, but it's a Free Fix for a common problem you may already have anyway. Next your TPS itself may be failing. Check the plug at connecting to it, next you might consider having it checked with a scanner for proper functioning or just replace it... |
i wiil look into it, i'll let you know,
thans Noralph. |
My 2002 F250 7.3 was doing EXACT same thing. It was the throttle position sensor. Part is very expensive new from Ford ($820
) because mine is 1 assembly with throttle pedal. You may want to search for used. A Ford dealer (maybe others) can hook their scanner up and watch signal from the TPS to confirm.
thank you for your help Kking.
You actually don't have to buy the whole thing. People have said this worked well as a replacement.
http://www.dormanproducts.com/docume...s_Sensors2.pdf |
i have bought the tps before and it cost less than $100 on ebay. but i,ll hook the scanner before. thank you guys.
